Lincoln Conveyor Oven - 1133-000-A Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 1456 n19811 how to reverse conveyor
Lincoln 1456
n19811
how to reverse conveyor direction
  • Anonymous Apr 01, 2014
    coupler hangs when running forward ,runs good in reverse
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5716
Points
5
Reverse a+ and a- on your conveyer control board or some newer models have a toggle switch on the back that you just switch to reverse the dir
mike
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Feb 05, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153538
Points
8370
If it's 3 phase, just reverse 2 of the 3 motor feed wires. It doesn't matter which 2. If it's single phase, the wiring directions should be inside the motor where the wires go in.
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 • Ovens
Hi i 'm looking for lincoln impinger 1456
Google search "Lincoln impinge" and find your local service agent.
1helpful
How to reverse the conveyor belt on a blodgett pizza oven
reverse the wires on the conveyor motor
Apr 20, 2009 • Ovens
Lincoln impinger pizzaoven
could be a defective pot or loose opitical encoder
1helpful
2answers
Lincoln Conveyor Oven - 1132
Switching phase on products are usually up to UL. You need a good tech and it can be done. If it is marked 3 phase and you make a single, the responsibility falls on the person that did the conversion. Components should be similar from 3 phase to single, just use OEM parts!
Top Lincoln Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
