Computers & Internet Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Pavillion m7177a, no sound
After loading XP Pro onto a HP pavillion m7177a I have no sound. What do I do?
  • estee123 Dec 17, 2008
    I have an HP pavillion slim line but a lcd universe monitor with speaker added. I have no sound but everthing say it should be working. Am I using a setting that would prevent the sound from working?
Anonymous
Level 3:
  • Master 611 Answers
  • Posted on Dec 16, 2008
Anonymous
Master
Level 3:
Answers
611
Questions
Helped
286021
Points
1229
Just installed the motherboard cd of your hp pavillion
There is no sound coming out of my hp pavillion dv4 1118ca
check the sound icon bottom right corner right click on it to adjust volume or to untick mute if this does not work you might not have a sound driver loaded.type in your comp details and download sound driver from internet.
hope this helps.
2helpful
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
How do i ghet sound back on this laptop? hp - mute on i think
1st check would be to see if the mute button is active on the soft keys if not. go into the control pannel switch to classic view open "sound" ( for windows vista and "sounds and audio devices" ( for windows XP) make sure that all of the mute tick boxes at the bottom of the volume control are un-ticked, hope this helps
1helpful
3answers
No sound after vista to xp downgrade on hp dv6910
Not sure of the entire model number but here are the drivers you will need.
Hp Pavillion dv9000 sound card driver for xp.
Go to NVIDIA website they have all the drivers.
Rate with 4 diamonds
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Hp slimline pavillion 1503 LCD 15"
plug the speaker cord into the LIME GREEN port on your computer.
Click on the speaker icon at thee bottom of the display to make sure you are not MUTED.
HP Pavillion ze2000
the boot sector is damaged at this time, try again the system restore, if all else fails you need to install a fresh OS XP home version be mindful of all your drivers cause you need this afterwards
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
