Wont turn on and red light is flashing where power button is located
Need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
I have a panasonic rear projection PT 56TW53. It will turn on for a couple of minutes but then turns off and wont turn back on unless you unplug and then replug the set. When it turns off, the red light flashes 3 times, pauses and then keeps flashing 3 times.
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
SOURCE: ON/OFF button (red - off and on - green) flashing all the time
it is important to count the number of red flashes, if it is 5 then the lamp ballast board has failed, (part #1-468-798-14) if it is 4 then the optical block fan (# 178706511) is probably to blame, if it is 6 then the thermal fuse has gone bad..(# a1137954a)
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
