I am have a problem with finding apacer 512mb unb pc2-4300 cl4 ram card timing for the bios
SOURCE: Problem with Mercury PI845GVM motherboard
fine ur problem if very simple as u installed 512 mb RAM on ur pc if at possible try to connect on to the other slot and restart the computer and check ur RAM capacity in ur os if it shows as same 256mb then ur have to change ur virtual memory settings i.e memory allocated to the video so configure ur virtual memory as per requirement then free up RAM memory ..
Steps for virtual memory configuration.
SOURCE: RAM not found as 2x512MB
Are you finding these number when you go into your bios or from a program such as CPU-Z? If you are using good quality DDR400 memory, it should be posting with the full amount of memory available. You are using the correct slots to get dual channel, but you may want to try slots 1 & 2 or 3 & 4 to see if it will post with the full amount of memory as single channel. You may also want to have a friend try the memory in their computer to see how it posts, you may have some bad memory.
SOURCE: Added 1Gb RAM DDR2 533 PC2 4300 CL5 but recognizes only 512Mb
the is a BIOS problem. you can still google search the BIOS updater. OR have a look on windows how much it is being detected.
and how 2 do it, my motherboard is a msi n1996ms-7222 pm8pm-v wit a 512mb RAM unb pc2-4300 cl4 dat i want the timing setting to.
