I bought a new i5808 replacement battery online from the vtech website, and received it yestereday. Question, how do I know if its charging correctly? My two phones(i5871 and i5808)were giving me a low battery,constantly loosing signal to the base and had static in the line after a year of use.(thats expected)I'm not sure if my phone is charging right. I let it charge overnight, and this morning I tested it and it seemed to work fine.(connection to base was excellent, no static and signal was not lost when walking aroung the house) When I went to put it on the handset charger, is displayed battery low. When setting the phone on the base and the amber light comes on, that means its charging right? Is there some firmware update im missing or a setting on the phone that I am not looking at the regulates charging options? This is a great phone and I love the options. I figured I buy a battery first and test it on the i5808. If it fixed the low battery, static, and connection loss issue I buy another battery for the i5871.
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Vtech supplies terrible batteries
My vtech i5871 loses connection to the base. It shows a full battery. Any suggestions?
I have the same problem as this with mine... Clyk.. your answer was great.. but what can I do to fix the mixed up codes??
THAT WAS NO HELP
