Sound problem
SOURCE: amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
SOURCE: HP HP ProBook 4510s - Core 2 Duo T5870 / 2.0 GHz -
You can only download drivers for the chip set that is in your laptop. Any other will give trouble.
Consult your manual or HP.com to be sure what is actually there.
Hope this helps
