Toshiba 27AF42 27" TV Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the converter box, but I'm not able to record very clear pictures from the VCR.
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Mar 09, 2009
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093703
Points
9665
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Set up installing antenna, tried Ant A & Ant B no receptiom what do I do?
The first question you have to answer is whether your TV is capable of receiving digital broadcasts. TV stations no longer broadcast the "old analog" signals, but now transmit only in digital format. If your TV is not capable of receiving digital broadcasts, you will need to buy a special box which allows you to receive digital broadcasts. Then you would hook it up in the order: antenna -> digital box -> TV.
If your TV is capable of receiving digital broadcasts, I've found that it is very important that your antenna have a pretty much unobstructed view of the direction from which the signal is coming. For instance, if your local signals are broadcast from the southerly direction, you should try to mount your antenna to a window which is facing south.
One last point before I forget, you must make sure that you select the proper input on your tv. For instance, I have cable, and a dvd player hooked up to my tv. Before I use the dvd, I have to go into the TV menu and select my dvd. When I want to return back to cable, I have to go back into the TV menu and select the cable input.
I have a TV sharp CATV bought in Belgium but installed in France where I cannot find the different channels. Can you send me the directions for use. Thank you.
Hello
The TV you have bought from Belgium, Sharp 25R-S100_ model can only recive NTSC [National Telivision System Commitee], signals only. It is not a multisystem compactable one. In France, the telivision boradcasts are in SECAM system I thinks and knows. [It is known as Sequrntial Colour and Memory]. The TV you have bought will work in US and other countries like that, where there transmission sytem is NTSC. I don,t know whether in France there is TV stations transmitting on NTSC system. If have, your TV will receive that transmissions. It is a system compactibility problem.
If the matter is so, nothing can be done to receive programmes transmitting in SECAM system. If a system convertable device is available in France, that is SECAM to NTSC system converter, you can connect it according to the instruction manual come along with that device.
Your TV is capable of receiving 181 channels and have PLL[ Phase Locked Loop] channel locking system, but have only capable of receiving NTSC RF signals. Ok
Toshiba TV 27AF42 purchased 7-2-02 Have cable
It's not the TV. Its the remote. Remote controls don't last for ever. Try a universal remote. Try Radio Shack it should do the job. Do you have a cable converter then ask your cable comapny to give you a new remote.
2helpful
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
1helpful
2answers
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
How do I tell if my Symphonic model is digital?
It is not HD , if this is wat you are asking.
if you have cable or are yousing sat you will have no problems reciving signals.
2helpful
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Toshiba vcr doesn't recoganize digital from sansui tv
is your vcr hooked up to your t.v. or through your cable or satelite box? if to t.v.,hook up through your cable or satelite receiver and this should solve your problem.... and should you need help with connecting cables to a receiver i can help you with that as well... i hope this was helpful...
Can't receive proper dvd/vcr signal
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
Recording instructions
First, whether or not you can do this will depend on cable box useage, and how the VCR is hooked up. In the earlier days of cable TV, & off-air reception, this was a simple task. If you have a satellite receiver box or cable box which is used to tune the channel, rather than using the TV itself or the VCR tuner, then recording one channel while watching another may not be possible. While I don't know the capabilities of newer sat/cable boxes, older ones sent just one signal out to the external equipment (TV etc.) That one signal (channel) is all that is available. If you received a manual with the sat/cable box, see if it says anything about this issue. That being said- if you don't use a sat/cable box, but instead use your TV or VCR to select the channel you are watching, then assuming the VCR is hooked up inline with the TV, just setting the VCR/TV option to TV will pass all channels through to the TV, and you can then use the TV to select whatever channel wished, while the VCR is recording something else. Hopefully I haven't confused you. If another contributor has some additional info on the capabilities of sat/cable boxes of today, please read their contribution.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
