Micro sd
Take your memory card out of the device and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). NOTE: Some cameras have image protection built into the on-camera software and you may need to configure this there.
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
SOURCE: remove write protection from micro-sd card
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
SOURCE: How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: My 2GB micro SD card
If it says write-protected, then... there is nothing you can do about it.
It's protected to not be formatted.
