Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
As far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
5. Control Panel > Internet Options > Connections (tab) > Lan Settings (button) then uncheck the Proxy server checkbox and check automatically detect setting
6. Control Panel > Internet Options > Connections (tab) > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
hatman ba in tanzimat moshkeleton hal she chon alan test kardam vase khodam javab dad.
1st sorry 4 my poor English.
if you have problem to sigin Yahoo Messenger(YM) .
1st you check the internet explore(IE)is working correctly. most of the time it don't work. (but Firefox,chrome,Gtalk,etc..etc.. are works correctly)
so go to IE ->Tools->Internet options->Connections->LAN Settings->
Check Automatically Detect settings and uncheck other options.
(See screen shot below)
Now IE and YM will work fine....
Thanks .. Mafaz ([email protected])
Yahoo messenger use the same connect configuration as IE, so check your IE connection ( Option -> Tools ->Connection ->Lan...) to ensure that your config is right
Click yahoo massenger
then
click massenger option
then
click perferences sub option
then
click connection via a proxy server and it sub menu HTTP proxy
then
click apply and OK
and log in
If you encounter error 81003004 in Yahoo! messenger, try this:
Turn off your Firewall and try logging in Yahoo! messenger
You may turn on after successful login.
Ihave this problem too but i can solve he problem by change your conection setting in preference: 1. go to messenger menu 2. select connection preference/ preference 3. the tab will automatic select connection preference, if it doesn't, select it manual. 4. change your internet conection type, for my problem i choose broadband *(DSL/Cable). hope this solve your problem best regards
It means you had an internet connection problem and one of your browser its working as offline without connection, after you fix this yahoo messenger will work correctly
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. If a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Hmmm... I had the same error last night (81003004). I'm not sure what caused it. I though at first it was a problem with our network. I'm still not sure though. The only thing I remember doing before the error is changing my default browser from IE to Chrome. After which when my YM got disconnected (which happens quite often due to my network connection), my YM could not reconnect again. I now have connection again. I'm not sure if this is the solution but what I did is just clicked on "Sign-In Problems"which redirected me to yahoo help page. I then selected the "My account have been compromised"... ans so on... and so fort. And that did it for me... ummm, i think?? ^_^
Try to close ym, after closing try open it up again and log in it...
K guys I encountered the same issue, The fix is simple jzt chk none of the default browser is set to "WORK OFFLINE",
Thats wat causes the issue for sure, cos Iv faced this issue wen I accidentlly had changed the IE to "WORK OFFLINE",But wen I changed this setting it immediately worked.
Hello, be sure you don't have a proxy in iexplore - tools - internet option - conection - lan setings - use a proxy server for your lan ... etc. If that proxy isn't working you can't conect to YM. hope that helps
Hi...this happens due to an issue in internet connectivity. Try disabling and enabling your wireless or wired LAN and connect again.
It will solve the issue.
After Googling and Following ALL suggestions Unsuccessfully...
i FOUND the CULPRIT to be AVG AntiVirus WEB SHIELD...
in AVG Overview Interface CLICK on WEB SHIELD then INSTANT MESSAGING TAB, UNCHECK Yahoo Messenger and Other Messenger You are USING...AND Puff...atleast this is how i FIXED my Prob:)
Simple just disable your firewall temporarily, i experienced that, what i did, i just disable my ZoneAlarm Firewall and viola!
The solution is that in your messenger you just to have simply check the connection preferences and have to enable the "Connect via a proxy server" then select "HTTP proxy".
I see. Please visit this site for more help! Click or copy and paste. http://softwarecritics.info/communication/resolving-yahoo-messenger-sign-in-error-81003004/
To setup Bellsouth email account in outlook, the easiest way is to reach BellSouth customer service. They provide an instant solution and help for email setup and password related issues.
Dial directly on 1888-315-9712
yahoo mail problems
connection > setting > check automatically detect setting & uncheck proxy
100% tested
81003004 try agan problam
Try each of these in turn
1) Start with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
2) On the sign in page click 'Messenger' > Conection
Toggle between 'Connect direct to the internet' and 'Proxy setting' make sure the information is correct in the lower 2 boxes
3) Check these settings in IE (even if you have another browser set as default)
a) Tools > Internet options > Connections > Lan settings > check 'Automatically detect settings - uncheck other options
b) Tools > work offline - make sure this is NOT checked and has a red X through it
4) Disable your firewall and do a trial sign in
5) Control Panel > Internet Options > Connections > Lan Settings-uncheck Proxy server and check automatically detect setting
Control Panel > Internet Options > Connections > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
To all YM users encounter error 81003004 or once you log to your ym their some error appears x000081 blablabla. The only solution for that problem is by using Advanced System Care 3.3.4 all in one software. Advanced System Care is free download but help you to fix all errors in PC system. If you want to have a copy of this software , copy the complete link and drag to your internet browser.
http://www.iobit.com/advancedwindowscareper.html?Str=download
If you want to know the complete information of Advanced System Care and what can do to your PC, follow this link.
http://impormasyon.info/2009/07/03/advanced-systemcare-334-download/
"Connect via a proxy server" then select "HTTP proxy", instead of 'direct'.
Please you guys try to write full email address just like hotmail.
I did it and my messenger was connected.
do rest of the setting which previously posted here and give it a try.
SOURCE: login error 81003004 from Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection Prefrences and use a http proxy.
thank you
SOURCE: whenever I tried to login in the Yahoo Messenger,
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this
is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
login error 81003004 from Yahoo Messenger problem
81003004 "connection problem" error message
i have the same problem. when i want to sign in it appears an error of connection which is called 81003004 please help me.... :(
login error 81003004 and 81003005
i have same problem
messenger encounted a network problem please check the network connection then try again ( 81003004)
@dinovoid
Hi, your solution worked for Log-in error 81003004. Although the default "internet connection" from my downlist was "dial-up", i changed it to the current internet connection I am using. And it worked.
IMO,Some who just installed Yahoo Messenger 9 encounter this problem.
Anyways, thank you so much for the help.
I have the same problem..Whevr I try to connect to the Internet it throws up the error 81003004...I tried chaging the connection settings from Dial-up but that didn't help me
i cannot sign in to my yahoo messenger. connection problem with 81003004 and 81003005.
please help me with this problem.
i have the same problem of login in......login error 81003004...pls hw do i go about it ????
same issue
I downloaded Yahoo Messenger 9.0 and it was working fine up until today. After performing a virus scan, it won't let me sign-in mentioning something about my internet connection, but I can access the internet just fine.
nothing is working to fix my log in error 81003004
yeah man i have the same problem
same problem occured during the time i use the yahoo messenger..please provide me a solution
same login error 81003004 from yahoo messenger.
same problem here
yahoo messenger login error 81003004
I can not sign in i try every thing and is not working
Messenger used to work normal. Few days back i started getting "Connection Error 81003004". My Internet Connection is ON and signal is Excellent. Firefox is up n running.
I tried solutions described in multiple pages including setting the proper connection to ADSL, but still no luck.
Pls help.
So would you please give me the best solution for this problem. I really need it.
Thanks a Lot
login error 81003004 from Yahoo Messenger ... :( same here!
When I try to login I get error code 81003005. Please help.
"login error 81003004 from Yahoo Messenger"
login error 81003004 when i wanna sign in YM...and also my IE Don connect to internet and any pages ain't open..but my fire fox open all pages without problem!
I can not login to yahoo messenger. I've try anyway but am not getting anywhere.
messenger encounted a network problem please check the network connection then try again ( 81003004) same one i have
messenger won't sign me in :-@
i did that n still have the same pro.
my connect via a proxy server is checked. why DONT WORK! plz i need help
Messenger encountered a connection problem. Please check the network connection and then click "Try Again". (81003004)
81003004
tis is not good
i want messanger now
coz i have receive one importand mails so plz solve this problem
FIX IT!!
always 81003004
81003004
it happens when i want to login on yahoo messsanger and it shows this eror number and i havent use my yahoo messanger since 2 month ago
hey i have this very latest 9.0 version of yahoo messenger .My messenger is showing this connections errors from quite a few days .i dont knw wot to do plz help........
i also have this kind of prob
what can i do?
huhuhu
when i try to login to yahoo messenger
I downloaded and installed to latest version from thier site 9… but gives me the error code (81003004)....... I removed the new one totally then restarted my PC installed version 9 again still the same problem[:(]
i want my password of chsaritha_86
Hi Fixya
A expert can help you resolve that issue over the phone in a minute or two.
best thing about this new service is you never placed on hold and get to talk to real repairmen in the US.
the service is completely free and covers almost anything you can think of Computers printers and all software issue by calling 1-(844)-465-4646
Hi guys, i must confess i just came across a reliable and incredible hacker who helped me track my cheating husband, you don't have to stress yourself anymore, if you have the strange feelings your husband or wife is cheating on you, be smart enough to contact him through his email (hotcyberclown @ gmail . COM) and you can also text him through WhatsApp messenger +1 (267) 526 5346. You don’t have to touch his phone or computer while you have access to his privacy/conversations ( Text Messages, Whatsapp, Facebook , IG, Snapchat, Messenger) through the software he bought and install remotely on my phone. i don't know how he did this but i think he's perfect at it.Tell him Grossing referred you, a trial will convince you, then you can thank me later. God bless
Kindly go to Yahoo third party service provider for help +1-(845)-477-5334.
