Got a used server from someone ( ho dl380 ge with 5i array) and the rbsu utility is in text command mode i want to return to the default mode...anoyone know the proper command to type in
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
SOURCE: Hp compaq prolaint dl380 g4
Even with out the display, can you ping it from the network? If not I would power off the server. Unplug the power. Take the cover off the server, reseat the memory. Pullout the both power supplies and reseat them. remove any cards in the server except the disk controller. Reseat all the disk drives, make sure you put them in the same slot you pulled them from, even though it doesnt matter. Plug back in and see if you get a display. You can move the memory around also or take out some. If you are not getting an intermittent beep or a red display on the front panel, your system board may be shot.
SOURCE: HP DL380 G4 Video resolution
To increase the resolution on a DL380 G4 try this.
So here is what I have done.
- Download x64.zip file from ftp://ftp.supermicro.com/driver/VGA/ATI/RageXL/x64.zip
- Run/Expand the zip to same directory
- DO NOT run the setup file or you will get the error message,
"Setup will only run in Administrator mode. Setup is aborting"
- Launch Device Mgr
- Expand the Video Driver and update Standard Video Drive. Point to directory x64.
- The server will need to reboot
- Display settings can be raised from 1024x786(16bit) to 1280x1024(32bit)
Note: 1600x1200 (16bit) is available but does not work on mine. If you set it to this setting and the video does not come back, connect up a higher resolution monitor and set it back.
