SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
SOURCE: How do I clean my Frigidaire Self-cleaning oven?
heres a link, yuoll be able to download your manual here. just need a model number
http://www.frigidaire.com/support/manuals.asp
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
