Motorola Mobility RAZR V3 Logo
Posted on Aug 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My motorola droid razor got wet from rain and shut off been about 3 weeks and still wont turn on and tried the whole rice thing too.what should i do?
Priyesh Vadher
Level 3:
  • Master 547 Answers
  • Posted on Aug 02, 2012
Priyesh Vadher
Master
Level 3:
Answers
547
Questions
0
Helped
133024
Points
1625
First make sure if battery is not damaged and is fully charged, if problem persist Show some official repairer to fix for you, probably your device has a short circuit problem.Best of Luck.
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Feb 04, 2008
SOURCE: Pink motorola razor
yes, as a consumer, you really have the right to do so and this is the best thing to do.
by the way, have you tried turning it on with your charger? anyway, you don't need to do that, you should return it.
Anonymous
  • Posted on Jul 01, 2009
SOURCE: my phone got wet
hi,my motorola razor got wet in the rain yesterday,the phone turns on and off,i can recieve phone calls and text messages,i just cant get the keyboard to work to try and make a phone call,or read my text messages
Tim Digibrain
  • 846 Answers
  • Posted on Jan 03, 2010
SOURCE: my droid gors to start up screen every 3 minutes
Try to do a firmware restore to make sure your system is 100% intact.Ifit still doesn't work, there may be an issue with your logic board.Ifyou're not covered under warranty there are Droid Repair guides that show how to open a droid.Watchout for the ribbon cables,those tear easily. Replacement parts areusually available on Ebay.There are third party services that can do itfor you Droid Repair.
JaxPlanet
Jax Planet
  • 923 Answers
  • Posted on May 10, 2011
SOURCE: I drop my motorola droid
It is very likely that you caused a short circuit when it got wet.
If you shorted the battery you can replace it. If you shorted the phone itself it will need to be repaired or replaced. You should contact your cellular provider for more assistance.
Charles A Stimeling
  • 172 Answers
  • Posted on Sep 02, 2011
SOURCE: My droid x got wet and after a night in rice it
Let it remain in the rice bowl for a bit longer, after per say another night of "cleansing," insert the battery, which should also be in rice, back into the phone and plug it into the charger give it say 10 min, and try to turn on the phone, if this doesn't work, then either your shelling out 80 bucks after insurance for another phone, or god forbid there is no insurance, try going back to a flip phone. They are cheaper and not as liable to leave you stranded on the beaches if it should get wet again :-P
How I can reset forgotten password on my Motorola DROID raz How I can reset forgotten password on bui Motorola DROID razor
Hello, Michael Tyler
To recover your password you can follow this steps
1. You need to access to your android device manager http://bit.ly/1bb3IjM
2. Sign in and select the *lock* option
3. Change your password
If this does not work try this How do reset my DROID RAZR
Regards
Kenny
Motorola Support
How can i turn my droid razr hd on?
In order to isolate the problem and verify why your phone is not working you can try to follow the troubleshooting steps provided in our Motorola Website: Motorola Support Find Answers Motorola Mobility Inc If this does not resolve the problem, you can contact us directly trough this link: Motorola Support Find Answers Motorola Mobility Inc
My droid 3 fell into the sink and got wet, it wasn't totally submerged it splashed into a dish that had some water in it, I put it in a bag of rice overnight and when I turned it on this a.m....
First thing is take out the battery and dry the battery with a towel or paper towel. Allow it to dry for a while and in the meantimelet you phone dry out. There is suppose to be a seal around the phones main board to keep out moisture so if it didn't get to wet it should be OK. After about 30 minutes the battery should be dry enough to put back in and then try to turn the phone on. In most cases it will work.
I drop my motorola droid 2 phone in the pool. dried phone w/ hair dryer and put in rice for 3 dayscbut does not work Can it be reset?
My droid x got wet and after a night in rice it still won't turn on. Any chances of fixing it?
1helpful
The droid got wet, it was not dropped into open wa...
Take everything out, the battery, memory card, etc and do NOT TURN IT BACK ON!!!!! get a big ziplock baggie, put lots of rice in it and submerge the phone in it as well as the battery. Wait 5 days. Then when that time is up, wait one more day. I mean it. This will save the phone. If you pull it out sooner, you could fry your droid. I know you don't want that to happen at all as those are way too expensive. Guard your baby with your life; do NOT turn it on until at LEAST 5 days have passed. Do you really need to see that email/txt so badly that you'll risk frying your phone? ;)
wait the 5 days and one more if you can. The rice trick works amazingly.
Droid got wet can it be repaired
Yes, take the battery and mem card out, get a big ziplock baggie, put it about half way full with white uncooked rice, put teh phone and battery in there and seal it up and DO NOT TOUCH FOR 5 DAYS!!!!
2answers
My phone got wet
ur mobile keypad might got slight damage... since it got wet.... u can go to th authorised service centre for motorola an get ur keypad service.... so that ur prob get solved..... kindly rate me .... thank you....
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
