Question about YDI Computers & Internet
Ydi ap plus won't reload factory defaults
Want to reset to factory defaults but it won't take
    Novelist:
    Champion:
  • 201 Answers
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
Posted on Aug 09, 2012
SOURCE:
SOURCE: reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Posted on Sep 17, 2008
mhusa68
  • 10 Answers
SOURCE: Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Posted on Dec 13, 2008
  • 62 Answers
SOURCE: I need to factory reset a Siemens AP2620
If there is no tiny push button on the outside of the box then the only way to reset it is loging into it.
If you can find the ipddress range of the non-working vlan that the AP is in you can change your computer ip address to one in that range and then access the router with it's ipaddress.
Once you get in you can use these steps to reset it:
a. Click the Wireless Controller button to open the Wireless Controller
Configuration screen.
b. In the navigation pane, click System Maintenance.
c. Click the Reset database to factory default and reboot button.
d. Click the Apply button.
This will reset the database and cause the controller to reboot.
Regards
Posted on Dec 20, 2008
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Posted on May 10, 2009
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
Cannot access my tp link TL-WA601G 108M Wireless Access Point
Use the Factory Default Reset button: First, turn off the AP's power. Second, press and hold the default Reset button then turn on the AP's power, until the system LED lights up (about 3 seconds). Last, release the reset button and wait for the AP to reboot.
Reset the factory defaults.
Here is your user manual:
http://www.tp-link.com/english/soft/20091515618.pdf
Default username and password is admin for both
May 20, 2012 | TP-LINK Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
Default Password for Proxim AP 4000 MRLR
The default password is should be "public" if it was factory defaulted.
Dec 04, 2010 | Proxim ORiNOCO AP-4000MR (8670-MR-LR)...
Factory restore
You can get a usb cd-rom drive.
Jun 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
YDI AP+
Press reset button and hold or 10 seconds.
Jan 23, 2009 | YDI Wireless Extended Range 802.11b Access...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Computers & Internet Logo
98 people viewed this question
Top YDI Computers & Internet Experts
Alun Cox
k24674
Are you a YDI Computer and Internet Expert? Answer questions, earn points and help others
