SOURCE: mstr2kx
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the
software that you downloaded.
The software installer will tell you when
to connect USB.
Some Canon printers are not Vista compatible and cannot work on Vista.
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: What is error B200 on Canon MX850?
The B200 error is a Voltage High Error. I read that you should try using a different power outlet and see if that works and if that doesn't work try cleaning the print head:
If it doesn't fix it then the board inside of the printer is faulty and you will have to replace the printer
Thanks.
-Sa_Les_Ski
SOURCE: necesito un programa para resetear mi impresora
Por favor, consulte esta p?gina para el restablecimiento:
http://www.aboutprinter.com/1952/how-to-fix-ip2770-canon-blink-orange-color
