Wheelchair lift stop work and had leaked fluid under platform. I am looking for how can I fix my self
SOURCE: Wheelchair lift electrical connection installation on 1999 K1500 Suburban?
More than likely your looking at the towing package for wiring a hitch to your vehicle for towing a trailer. Probably can use some of that, but I'm sure if you stopped in at a GM dealer and explained what your trying to do, they'd have someone look & confirm for you that it's o.k. or not to use that harness, without a big service charge.
SOURCE: ford econoline van leaking unknown fluid HELP!!!!!!
check your enging fluids could be brake fluid or power steering fluid. the wheelechair lift is most likley electric and does not require fluid of any kind
I found out leak from pressure switch PS 72
