The Print Screen Key will be placed at different place on different manufacturer Keyboard but it is usually lies within Scroll Lock, Pause Break Keys on Keyboard. Some keyboards short named it as Prt Scr SysRq.
Please see this screenshot for finding Print screen key on Keyboard.
Click Start Collapse this imageExpand this image, type intl.cpl in the Start Search box, and then press ENTER.
On the Keyboards and Language tab, click Change keyboards.
Click Add.
Expand the language that you want. For example, expand French (Canada).
Expand Keyboard list, click to select the English(United States) check box, and then click OK.
In the options, click View Layout to compare the layout with the actual keyboard.
In the Default input language list, click English(United States) - English(United States), and then click OK two times.
In the Regional and Language Options dialog box, click OK.
Note The Language
bar appears on the taskbar. When you rest the mouse pointer over this
bar, a tooltip appears that describes the active keyboard layout.
Click the Language bar, and then click English(United States).
Windows XP
Click Start , type intl.cpl in the Run box, and then press ENTER.
On the Languages tab, click Details.
Under Installed services, click Add.
In the Input language list, select the language that you want. For example, select French (Canada) .
In the Keyboard layout/IME list, click English(United States), and then click OK .
In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
Note The Language
How to make sure that the selected layout matches the keyboard
Windows 7 or Windows Vista
Click Start, type osk in the Start Search box, and then press ENTER.
Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
To check the uppercase characters, click the shift key on the keyboard
or on the screen, and match the characters printed on the keyboard.
Windows XP
Click Start, type osk in the Run box, and then press ENTER.
To
check the uppercase characters, click the shift key on the keyboard or
In wordprocessing or email the backspace key deletes the previous charachter and isnot the same as the Delete key which deletes the next charachter.
On my girlfriend's french pc the delete key is marked "Suppr". It works to delete the next character and also for the "executive override" function which will reboot an old pc or get you to Task Manager in windows.
I'm not sure of which French keyboard you have, The Azerty is from Belgium and is used by the French, there is another that French Canadians use, it is a modified Qwerty. The Azerty board has the key "Syst" on it and this key is sometimes used as a screen print when used with a cimbination key strike. I am unsure if the combination uses the shift key, the Fn key or the Alt Gr key. If your keyboard has a menu key, this also may bring up a keystroke guide to use.
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
You need to tell windows it has a french keyboard:
In the control panel, go to regional and language options. Go to the keyboards and languages tab, click change keyboards. On the window that pops up, click on the general tab. You probably have just the us keyboard installed. Click add, then choose either english-canada or french-france, then click to add the french keyboard. Click preview to see where the accent keys will be (so you can find them). Now, select the french keyboard and click 'move up' so the french keyboard is above the us english one.
go to bottom right of your task bar and click on small keyboard icon (it may also be in the top right of your screen)...then scroll through and pick the language you want
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
