Lexmark X2500 All-In-One Printer Logo
Conroy Lewis Posted on Nov 30, 2017
Lexmark x2500 won't photocopy
When i put a document on the scanner and press the photocopy button nothing happens. When it first started first started to act up it would take 30 sec - 1 min to actually photocopy a document but now it just won't copy anything. Printing documents from my laptop is fine, i just can't photocopy anything...
5 Related Answers
Anonymous
  • 1447 Answers
  • Posted on Apr 05, 2008
SOURCE: Lexmark X 83 will photocopy but not print
Ok thanks for the info:
Do you still have the the Installation disk for your printer?
Anonymous
  • 134 Answers
  • Posted on Dec 02, 2008
SOURCE: lexmark x2500 err msg: UNABLE TO CONNECT
What you will see
When trying to print, you get a communication error; the device is correctly detected in the Device Manager, the firewall is not blocking any files and you can scan using the All-In-One Printer.
Explanation
Any PC using the AMD USB architecture is preventing the printer from printing when connecting via USB.
What to do
Follow the specific steps for the PC manufaturer below:
Dell Studio 1536:
IMPORTANT: Do not replace any hardware, before performing the following steps:
Step Action 1 Go to Control Panel 2 Go to Programs and Features 3 Uninstall AMD USB Audio Driver Filter
Note: Uninstalling this USB audio driver doesn't cause any impact for systems with Vista Service Pack 1 installed
Acer Aspire 5530, Extensa 4130, Extensa 4430, and TravelMate 4530:
There are files available to address printing problems when connected to a USB printer or multi-function printer, for Windows Vista and Windows XP.
  • Printer did not print, print jobs will be listed with the status "error" in the task list
  • No error message appears, printer simply does not print
  • Problem only manifests when the printer is connected via USB
Please go to the Drivers and Downloads area to get the file appropriate for your operating system and unit.
US Customers:
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_Vista_Setup.msi
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_XP_Setup.exe
EMEA Customers:
ftp://ftp.work.acer-euro.com/notebook/aspire_5530/vista/Drivers/USBFilter107_Vista.zip
IMPORTANT: The third-party products discussed in this article are manufactured by companies that are independent of Lexmark. Lexmark makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
Still need help?
If you need additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need your printer model/machine type and serial number.
Please call from near the printer and computer in case the technician on the phone asks you to perform a task involving these devices.
I hope it helps!!!
Sanath Kumar V
  • 684 Answers
  • Posted on Jan 16, 2009
SOURCE: Lexmark Imaging Studio
The Downloaded software may not have the Lexmark Imaging Studio on the downloaded drivers.... In this case u have to scna and Preview the scanned images using Windows Photo Gallery..... Click on File and Click on Import from scanner or Camera........... Then again click on Import...........It will scan and preview the Applications to u.... Thanku.......
Healeyman
mike kirschbaum
  • 1198 Answers
  • Posted on Apr 27, 2009
SOURCE: can't scan a document
Maybe it wants you to hit a start button in the computer program, to start the computer receiving the scan. Try to get an owners manual, sometimes there's one in the install cd.
Anonymous
  • 191 Answers
  • Posted on Sep 17, 2009
SOURCE: scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
2answers
I have a lexmark x5630 printer. Since last week whenever i try to photocopy a document, it only copies 1/4 page, not the full page.I have tried to change the "Resize" or "Size" but...
If you're using the Lexmark X3650 printer, try to reset the printer to its Default Factory Settings. Please follow the steps below:
  1. On the printer operator panel, press Setup button.
  2. Select Defaults.
  3. Select Set Defaults.
  4. Select Use Factory.
Then try to make a copy again to verify that the problem is fixed.
2answers
How do i photocopy ?
Put paper under scanner door, and hit Copy
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
1helpful
How do I scan a document into my computer with an EPSON printer?
You need to have OCR (Optical character recognition) software on the computer. There are several free programs avaliable. Do a google search for OCR. That will give you a location on your computer to send you document to.
2helpful
Can I photocopy without the computer as it is not working at the moment
You shoulde be able to insert your document into the scanner section face down, close the lid and just press mono start or color start and it photocopy for you. as most of the printers now a days dont need a computer to operate hence why some are called standalone machines.
I have a 2500 printer/scanner. The unit prints and copy's fine. How do I get it to scan a document. The panel button seems nonfunctional.
There should be an icon on your computer for your scanner. Make sure your printer is hooked up, click on the scanner icon, and follow the directions. Hope this helps.
When pressing scanner to computer button nothing happens
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 2500 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
Copying
just place the document or photo which you want to copy on the scanner glass and then press COLOUR/BLACK option which you require.and keep the copy option ON in the printer .it will photocopy what you want.
thanks.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
