Konica Minolta Dynax 5D / Maxxum 5D Digital Camera Logo
Anonymous Posted on Aug 01, 2012
USB cable randomly stopped working with my computer?
I've not had any complications when it comes to uploading photos with this camera at all until now. When I plug the USB cable into both the camera and the computer and turn the camera on, something usually pops up on the camera screen that says "initializing usb connection" that will remain there the entire time i'm uploading photos. But now when I try to upload my photos, the "initializing usb connection" thing only pops up for around 3-4 seconds before it disappears, and then my computer won't recognize that the camera is plugged in at all. Does anyone know where the problem lies?
Anonymous
Level 3:
  • Konica Minolta Master 32,281 Answers
  • Posted on Aug 02, 2012
Anonymous
Level 3:
Answers
32281
Questions
Helped
7912612
Points
102259
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
2 Related Answers
  • 102366 Answers
  • Posted on Apr 20, 2011
SOURCE: can not upload pictures from
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Anonymous
  • 59 Answers
  • Posted on Dec 02, 2008
SOURCE: Turns the computer off when plug USB into a computer
did you try using the camera with a different data cable? there could be a peoblem with the data cable you are using
Can't Upload Pictures
Try putting the memory card in a USB card reader attached to your computer, which should see it as another drive. Write-protect the card first.
2helpful
I have an hp photosmart 435 camera. I use Windows Vista. For 4 years, I have been able to upload photos without a problem. The camera shows it is establishing a connection to the computer but no di
Hi !
1. Try different few things. Delete yor software and driver for your HP . Clean Registry( Start/Run -> regedit) deliting all HP keys and strings of the camera's software.Restart your computer. Reload HP software and driver on your PC with proper driver ( 32 or 64-bit OS) http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=213533& .
2, A corrupt PID can prevent a USB device from working correctly in Windows. Removing the PID key and reinstalling the software for the device may resolve the issue. Follow the steps below in the order given to remove the PID keys.
3. Did you try to connect to another PC ?- ( First download HP driver on this PC). - It will help you to eliminate possible camera's itself problem.
1helpful
I can't upload my photos from my camera to my computer! help?
You neglected to specify the make and model of your camera so I'll assume it uses a memory card of some type.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 15, 2012 • Cameras
1helpful
2answers
Most recent pics won't upload- you can see them on the camera screen but won't upload
Need to find way to upload pictures to computer without usb cable or someway to hook up different usb cable
does your camera has a usb port? if it does try finding the appropriate usb cable, if it doesn't check if it has any bluetooth or some other connectivity devices.if it does you will have to install a bluetooth device to your computer in order to transfer photos and videos.
1helpful
Wher can I buy a usb cable for my Polaroid m737t?
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't cost much more than a USB cable.
1helpful
I have a fujifilm s2950 camera and I'm trying to upload photos onto my computer. For the first time yesterday when I plugged the cable into the computer and turned the camera on nothing happened o
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Uploading photos "camera Error"
1helpful
I can't upload photos from my nikon coolpix s210...
its easy to upload your photos..first store all the photos in your desktop which makes it a faster process to upload..(upload using picasawebalbums)..coming to your problem did you try to do the same in some other computer..if its working in some other comp, the check your usb in the comp.try to connect it to other usb hubs nd check it out..
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
