Question about Konica Minolta Office Equipment & Supplies
Scanning to e-mail - Bizhub 215
Hi, I cant get my Bizhub 215 working for scanning to e-mail. The problem is that in the settings there is no "authentication" for SMTP server. There is e-mail but NO PASSWORD option - but I have to enter password when I want to get into SMTP. So how do I do that? Thanks, Karlos
    New Friend:
I don`t have Admin. 2 in my KONICA MINOLTA bizhub 215 so I can`t go to software sq and I can`t change mode selection. Do You have any solution?
Posted on Sep 15, 2015
This setting is only for bizhub 200 - 350
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Posted on Jan 03, 2013
  • topico Aug 25, 2014
    Unfortunately, this model Bizhub 215 supports scan to e-mail client only SMTP without authentication, which at this time is very outdated. It should rather choose another method of scanning. Wia / Twain, FTP, SMB.
2 Suggested Answers
SOURCE:
SOURCE: Cannot Scan To E-Mail
Solution
3. Admin. 2
4. Software SW
Posted on May 19, 2008
Conika minolta bizhub 215 error code c6101
The scanner is not going back to home position, have a tech come out to check this. The scanner is what moves when scanning a document on the big glass or if using a document feeder
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 08, 2017 | Minolta Office Equipment & Supplies
Scanner does not reach e-mail
check that machine is set up with static ip address and correct port mail smtp is port 25. check your mail server
Feb 10, 2014 | Konica Minolta bizhub 200 Printer
Bizhub 352 not scanning to emails
Check your DNS and Mail server settings to make sure they are correct.
If your mail server uses authentication you will need to turn this on and input a user name and password for your mail server. To turn on SMTP authentication you must enter service mode and change switch settings. I would recommend contacting a local Konica Minolta deal and have a technician do this. If you change the wrong switch setting you will cause all kinds of problems.
May 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Jul 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Scanning to email
The majority of the time when scanning stops working is the ISP has changed settings, whether it be the smtp server itself changing, the ip address of the smtp server changing, or they have turned off non authenticated relay. Have you tried scanning to your computer instead?
Nov 16, 2008 | Konica Minolta bizhub C250 All-In-One...
SMB Scanning to a Macintosh
I don't know if SMB for a Mac is supported on Bizhubs. I know it works with Microsoft workgroups. The only other way to get around it is to scan to e-mail. Then retrieve the e-mail from a Mac.
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 - can't network scanner
Unless you are scanning to e-mail in which case you will need to put in the SMTP mail server settings into the admin section of your network settings.
Mar 07, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning Problems
mail server issue. check your outgoing mail server. Most smtp depends on your isp. for instance, use smtp.sbcglobal.net for at&t isp. if you have an exchange server use your exchange server's outgoing mail.
Hope this helps!
chris
www.willhelpu.com
Jan 22, 2008 | Konica Minolta Bizhub-200 Minolta Printer
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
2,198 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
