Wont start runs for a second on choke then cuts out im geting a spark ive put new fuel in with oil 50.1 it has chain oil air fillter is clean its only bein used once before for 2 mins and wont start now
SOURCE: I just bought an Hitachi
Did the chain tighten up or is it hanging a bit from the bottom of the bar???
Have you made sure to keep bar oil in it??
If the bar and chain are not getting oil the chain will tighten up and stop....
If the chain has oil and it a bit loose.. it should hang just an 1/8 in. to 3/16 in. at the center bottom of the bar....then the clutch has gone bad already and you should have that fixed under warranty...
heatman101
