since it is piotless how did you light burner pilots? The oven is piotless and does not have a free standing pilot. here is a link to manual copy and paste page 18 deals with oven.
For a detailed Range/Stove/Oven illustration, click below.
Gas Free Standing Electric Free Standing Gas Cooktop Electric Cooktop Gas Walloven Electric Walloven
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
If the stove is the one that I think that it is... you will have to lift the cover and then between the burners there will be a small orifice that you light... the pilot light will then light the burners when the gas is turned on to them...
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
WHERE IS THE CONTROL TRIPPER SWITCH LOCATED?
