My subwoofer has a small crack and I was wondering if anyone had an idea on how to fix it, or do I have to buy another one? Please help me, I'm kind of broke to replace it with a new one. Thank you
Duct tape pulleese, if the crack is small enough use a little clear nail polish this will effect a clear seal and no re-verberation.(duct tape will break loose after about 2 minutes). if the polish does not work a smattering of (gorilla glue) will do the trick.
If you can get to the back of the speaker cone you could try a little touch of duct tape over the back of the crack. Pretty strong stuff and if your lucky no one will ever know!
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
