SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
SOURCE: My 1994 Mercedes Benz SL500 radio display turns on, but no sound?
I had same problem with my 1994 SL600. Also when this happens you will lose your interior door lights when you open the doors. My problem was solved by taking out the, A-white 40 amp 12V Relay and cleaning off the 6-prongs and reinstalling. It is located in the box underhood ahead of the main fuse box. Just need a phillips screwdriver. It is the fartherest relay in back left. I had to pull the one out in front of it to be able to remove the white one. You can hear it click when you push in dooropen switch. When working right you do not hear it. Hope this helps.
SOURCE: Merces Benz s500, Ignition key does not turn, can
Check Battery in car(make sure is not weak or dying), check battery in remote fob, possiable draw in system possiable fuse or possiable keyless entry module failure
SOURCE: How do I unlock the shifter on a 2000 Mercedes
No you do NOT need a new transmission.
This model Mercedes uses an electronic solenoid in the shift housing, to take the linkage out of park.
There is a small plastic part, activated by a solenoid that pushes a release, allowing the
shifter to come out of park. Most of the parts in the box were metal.
This particular part is plastic and very frail.
It is not an easy job, but any mechanic can do it.
SOURCE: My 2000 Mercedes Benz S500 is dead- electronic key does not
It's not that unusual for a battery to fail that soon, and the "no lights, no nothing" says that it's the battery again. Your best bet at this point is to pull the battery and take it to the point of purchase for testing. They should either replace it under warranty or charge it for you. After you replace the battery you should have the charging/electrical system checked for possible shorts or power drains.
BillB
wanted to re install inn another mercedes
