My LG LED model 32LV2400-UA TV won't turn on. Had it since dec. 2011. Worked fine in the morning, then wouldn't turn on using the remote or TV on switch. Tried unplugging. No luck
TV won't turn on using the remote or "on" switch on TV. Tried unplugging it. No luck. Red light is illuminated.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
I looked at the previous solution but I would be more apt to say you need to look at the capacitors on the power supply. It is a very common problem, especially for a TV that is on more than it is off. Simply pull the back cover and look at the capacitors on the power supply. It will be the board in the middle. If a couple of them are domed at the top or leaking then they need to be replaced. If you have someone that can do a little soldering for you the repair could be as cheap as $5.
