Nokia N70 Cellular Phone Logo
Posted on Dec 15, 2008
I want program for my phone?
I want programs and games for my phone
  • Anonymous Dec 15, 2008
    Starting is very slow around 75seconds. is there any solution?
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Dec 15, 2008
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
8493
Points
45
1helpful
How do i keep my phone from freezing up as soon as it starts up
you have to many apps running and programs
you need to remove a lot of them
here is whats going on lets say you phone is a empty jar, and the apps are sand, i take a funnel start pouring sand into the jar, at some point the jar is going to fill up. my phone has lots of appts., scanner, music, games, anti virus programs, management software, youtube,
phone numbers, data information, bank stuff, password programs, and so on.
when you turn the phone off at night to charge the phone, than in the morning you turn on the phone, your phone has to load all the appts,
programs, games, bank info., anti -virus and any other program you installed.
you have limited amount of memory and the phone is trying to load all the program and turn on the phone and run other options.
_____________________important to try______________________
go into phone store look for a program called the following
CLEAN MASTER it should be free
it will help with junk files, privacy, memory boost, app manager
_______________________________________________________
also in the program there is a advanced section that will allow you to move some program from the phone to you micro SD card if you have one.
i hope this this will help resolve a lot of issues, keep the phone a little cooler, when you put thing on the sd card they are stored on the card not the phone when the phone turns on everything on the sd chip is loaded into the memory of the phone there should not be loss of time or long waits for the appts to activate or run
2helpful
I know there is a game on the phone but i cnt find it, plz can you help.
The game should show up in the list when you press the 'Programs' key (lower left of the screen if your using the default launcher). You can also try to redownload it from the market or reinstall the .apk if you side loaded the program.
you can also confirm that the program is installed by going to Settings->Applications->Manage Applications and see if the game is listed as being on the phone.
A way to unlock games on L7 so i can send them via bluetooth?
from what i have found out and discovered with there is no way to do it but i found this new program called tkfilexplorer the program isnt fully stable but shouldnt crash your computer, i have it on mine.. anyway, the program allows you to move, delete or copy att program stuff that you usually cant even touch or look at, i cant explain how to use it for either of your phones becasue i have neither of them but try that.. do a little research first though on the program and how to use it!
Samsung sgh 480 can't read downloaded game's,dictionary etc.
Tocco accepts only java programs and games but sometimes not all java games are supported.Usually games or programs are having the file type .jar.Try something else
1helpful
Apps wont work
Supposing these games and apps are installed correctly the problem is that most games and apps you find are for phones with a 'certain' number of keys, and the i9 has NONE ... the only solution is to try and convert them with a program called 'JAM'. This program 'tries' to convert programs to work with the stylus instead of keypad .... sometimes works, most times doesn't ....
I dont know to install games in my moto V3 i also dont have softwares
you need either a data cable or an internet connection on your phone to download a program. you also need enough memory space to do all these. browse the internet for the type of programs that are supported by your phone. they might either be symbiam programs or java programs. also have the phone software installed on your phone for other transfers.
Please
First, download program called Bitpim (it's free) Then install usb drivers for your phone. You will then be able to use the program to put ringtones, pics, video, games and anything else on your phone and the program also can read data that is already on your phone.
3helpful
2answers
Executor program
Hi I find the solution to the problem 'executor', the problem is that the man who unlocked phone vort forget to remove the executor program is a program to unlock sony ericsson phones.
So you must ask him to remove the program from your phone, it will very well come when the problem.
And your phone will turn on again.
How iam dowenloding games in mobile w700i
u can use a software named MOBILedit! i can help u this way========
Activation code: MRRMU-FHAD9-VUC5V-EY4A0-5M0MA
Company: leave it empty
Download last vers.MOBILedit!
2. Delete the previous version of the program.
3. Delete from the register this branch
[HKEY_CLASSES_ROOT\CLSID\{6e7110c0-ac8e-11ce-ad01-70aa0051e4a1}]
4. Install the new version of the program
5. Register the program
LETS TRY
How to tranfer games from to -phone via ubs coord
All depends on the brand of phone and how new the phone is that your trying to get it onto. For instance, games on a samsung phone wont work on a sony or motorola. Games from an old nokia wont work on a new one due to copyright protection programmed into all phones.
Mar 11, 2008 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
