Navman f25 has been completely wiped....how can i get it back up and running?
SOURCE: Navman f10
my navmanscreen went black now it shows a computer screen with anavman on other side with x on it could you help my email adress is [email protected] thankyou
SOURCE: navman tcn 320 gps
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
SOURCE: navman icn 320
carefully pull off front grey cover with your thumb, next to card socket, underneath are 4 security screws you need a small torque head screwdriver, take off cover losen security screws inside around battery, unplug and remove battery, replace in reverse.
SOURCE: navman s50
Try this link
http://www.activegps.co.uk/car-navigation/navman-s50/navman-s50.pdf
SOURCE: f20 navman error
I have had the same problem and did what gossages recommended and it worked straight away thank you very much!!!!
1. Connect Navman
GPS to PC via mini-USB cable.
2. Go to
'Start'
3. Go to
'My Computer'
4. Open the
Navman Unit
5. Open the
'Navman' folder
6. Open the
'Database' folder
7. Delete the
following file only - 'dababase.db'
8. Close the folders
9. Disconnect the
mini-USB cable then restart the Navman GPS by sliding the switch to
'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
