Question about Roland Juno-D
Roland juno di service manual - Roland Juno-D
    Top Expert:
  • Roland Master
  • 51,852 Answers
Order the manual directly from Roland.
Posted on Nov 19, 2018
SOURCE:
SOURCE: My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
Posted on Jun 01, 2009
  • 5603 Answers
SOURCE: roland juno-d, keys are either too loud or too
Normally you have to clean the conductive rubber "pills" AND the circuit board traces they get pressed down on.
USE ONLY 99% isoprophyl alcohol on Q-Tips to do the cleaning and be gentle.
Use of other product like deoxit and other contact cleaners will wreck the contact material.
Posted on Jan 12, 2010
djlaplaya
  • 74 Answers
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Posted on May 06, 2010
SOURCE: I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Posted on Sep 14, 2010
  • 1212 Answers
SOURCE: roland juno d not work
Check the power adapter at the coaxial plug end that plugs into keyboard- is there power there? If so, is the socket on the keyboard loose at all? If so- the socket may be broken, If there is no power there, you either need a new power supply or you need to open it up to see if it is just the fues in that supply that failed.
If the plug inserts snugly as it did when new and it dopes not power up, the issue may be the power switch on the back- it may have dirty or corroded contacts- cycling the switch on and off several times rapidly should clean it.
If it still does not power up, there should be a fuse internal to the keyboard that would require you open it up to check it. If it is not under warranty, this is not an issue- if it is under warranty, it is something that should be checked in the shop.
Posted on Apr 07, 2012
How to program arrpeggiator in Roland Juno D
The information is in the manual. You can download a copy here-
JUNO Owner Manual JUNO Manuals Support Roland
Feb 27, 2015 | Roland Juno-D
Some keys of my Juno Di got Out of tuned :( pls help
Un screw your DI and remove the rubber pads under the keys and gently whip any liquid under it and on the key on it .the liquid is acting as resistance to result in de tune.
Nov 19, 2013 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Where do I install the expansion card on Roland Juno stage
You install the expansion card to the bottom side of the Juno by removing screws. For detailed step by step instructions, I suggest that you refer to page 174 from the manual that you can download from: JUNO-G Owners Manual (JUNO-G_OM.pdf)
Apr 17, 2011 | Roland Juno Stage EXpandable Synth
In juno di faviourite button when i bush one after another there is sound gap in tones ie fraction of second gap
This is probably normal. The sound generators need to re-configure when changing voices. This means that while one set is generating the old voice, others have to be set to the new and the old cancelled. The sound has to be muted between the setting changes... this takes a fraction of a second to do in the hardware. The only solution is to use two synths and have each set to the sounds you want. MANY musicians rack up two synths just for this purpose.
Oct 15, 2010 | Roland Juno-D
Faurite buttons bushed there is a quarter note gap in sound in juno di how can i solve
Not sure what you mean by "buttons". IF you are trying to change voices, a lag between sounding of the old and new voice can be expected as the generators within the synth are reconfigured for the new voice. This is a lower-end synth and as a result doesn't haved the performance of some of the newer ones.
If the lag is just between notes that are being keyed using the same voice, that is too much delay and something is probably set wrong.
Oct 15, 2010 | Roland JUNO-D Synthesizer
Can I update roland Juno G Old version to new?
Here is the link you need but pay absolute attention to the Please note section in each case as the Juno D LE and the original Juno D are different. If you install the wrong update you will have problems with the keyboard working at all.
Jul 17, 2010 | Roland Juno-D
Every sound is modulating as if there's tremolo on
If you have the new Juno here is a link to their update:http://www.rolandus.com/products/productdetails.php?ProductId=429 Also try looking in your manual for the initialisation procedure. This will return your keyboard to the factory settings .
Feb 28, 2010 | Roland Juno-D
Feb 06, 2010 | Roland Juno-D
Roland juno-d, keys are either too loud or too
Jan 11, 2010 | Roland Juno-D
May 31, 2009 | Roland Juno-D
Roland Juno-D Logo
714 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
