The machine stops and the "01" Fault Code flashes. If we hit start, the cycle begins again but then stops again. On permanent press this will happen 2-3 times. On delicate 1-2 times. We have replaced the water inlet valve (Is there more than one?) and the control panel module. We have been advised that the circuit board must be replaced and that costs more than $300.00. Are there other possibilities to check first? Would we be foolish to put a new circuit board in this washer? What else might go wrong? Bosch does not sell a replacement washer they say could be used with our dryer
SOURCE: My bosch wfk 2401 when i start the wash everything
Hello and welcome to fixya.
I'll start by saying you're right the "01" error code is indicating a fill problem has been detected by the control.
Have you tried just a "cold" water wash ? If not try selecting "quick wash" and on the dial turn it to #1 "cold" in the cotton setting see what happens. Do the same and select #3 "hot". If the error occurs in one and not the other, observe and either focus on the hot water valve or the cold main wash valve ( I don't think it is the cold prewash valve or the error would occur immediately ).
In fact I suspect it is the main wash cold valve ( dual valve ) since you haven't indicated the error occurs during prewash and the hot water valve is energized in prewash by design to help rinse out the detergent no matter what cycle or temp. you selected.
Having said all that, here's what you're dealing with. Even though you appear to have sufficient water flow as you stated you checked for, the electronic control doesn't think it is correct.
There are several factor's which could possibly be causing this error, a couple you've mentioned.
They are...
Water supply turned off. ( obviously not in this case )
Water inlet hose filters (strainers/screens) blocked. ( you've said you cleaned them out )
Water pressure too low. ( must be no lower than 14.5psi and a max. of 145psi )
Water inlet valve(s) has failed. ( this doesn't appear likely...at least at first, not completely failed based on your description...but the control may think it has. If you have an ohm meter you can check it. the coils should have a value of between 2.7 and 3.3k ohms. That means 2700ohms and 3300ohms. If not within those values the control will detect the value being incorrect , hence displaying the "01" error. Change the valve, Bosch part # 265772, or repairclinic.com # 467537.
The Hot water valve if need be is Bosch part # 171295 or repairclinic.com # 423900 )
Control module has failed. ( Not very likely either...but possible...if not the valves. )
Let me know what you find as I will watch for your reply here. Thanks for visiting "fixya". Please take a moment and rate the info provided for you here today.
Let me know if you require further assistance.
Thanks and good luck.
macmarkus :)
Testimonial: "macmarkus i did a wfk 2401 washer test and when i did this portion of the test,Dual cold water valve (Pre-wash) ? Push Pre-wash button (Pre-wash light comes on). Push button again to end test. Water from left half of dual inlet valve (viewing front of washer) flows into right side of dispenser. Pull dispenser door slightly to view water (without splashing). i did not have any water at all so i do think it is the valve. do you concur? sincerely, mary"
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
SOURCE: I have a bosch wfk
Could be an iffy valve/ solenoid. One test is to see the empty machine slowly fills up with water, if you leave it for a few days. You can isolate teach valve by turning each feed off in turn. i t could be leaking all through the cycle. If it is flooding during the spin I'd check your pump at well. Hope this helps.
