SOURCE: WD 2 TB external HDD asking for password
log in from administrator see if your anti virus's or your windows fire wall is not interrupting if not solved go to run in the start menu type command "chkdsk" "netuser administrator (the password you want to give)"
SOURCE: cannot copy files directly to WD external 250gb HDD
Ensure you are on a USB 2.0 port ! that is most important
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
SOURCE: WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
SOURCE: XP, Vista and Win7 recognize
You'll need to check and see if the disk is formatted and recognized as a logical disk. To do this, Go to Start, and locate the Run option, and type in diskmgmt.msc or you can go to My Computer, right-click it and select "Manage" from the popup menu. Then, at the bottom of the list to the left, you'll see the Disk Management submenu.
Once you're in the Disk Management applet, click on the WD from the list of available hard drives from the list, and see if the partition is recognized as formated. If it's not formated you may need to format it. If the disk is recognized as RAW disk, then you'll need to first create an extended partition and then format it with NTFS file system. REMEMBER, if you can access the drive from another computer and it's recognized properly in Explorer, then formating it will erase all data on the disk. But if you never used it before (i.e you dont have any data on it) then you can go ahead with the formatting, which should solve your problem if it's a software issue.
If you heard your disk clicking for a while in the past, and you had problems with it: slow reading of files, sluggish in copying files etc. then your hard drive may be mechanically failing and in this case there's nothing you can do to save it. If this is the case and you still have warranty, return the disk to where you bought it from, and ask for a replacement.
If this was informative and helpful please vote with a Thumb Up. Thank you.
