"Lubricat deck" appears everytime it's turned on. I've lubricated the deck several times but still get message. I can push STOP to clear it but how do I get this message turned off after lurbicating the deck?
You will need to recalibrate the machine. Call Treadmill Doctor at 800-750-4766 and they will help for free.
http://www.treadmilldoctor.com/troubleshooting-tests-and-adjustment?utm_source=fixya%2BANSWERS&utm_medium=cpc&utm_campaign=MENDI
SOURCE: I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John
Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
SOURCE: Hi my belt is slipping.
Does the belt stop while walking or running? Does it staop after it has run for a while? Does the motor seem to stop too? or can you hear it running like normal?
Let me know, It is most likley the pully on the front roller.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
SOURCE: Screen states Lube Belt ,
hi, It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness. • Turn off the treadmill with the on/off switch, then unplug the power cord at the wall outlet. • Loosen both the rear roller bolts. (For best results, place two removable marks on both sides of the frame and note roller position). Once the belt is loosened, take the bottle of lubricant and apply it to the entire top surface of the running deck. Tighten both rear roller bolts (matching up the marks for proper position) to original position. After you have applied lubricant, plug in the power cord, insert the safety key, start the treadmill and walk on the belt for two minutes to spread the lubricant. • Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
SOURCE: belt was slipping (sticking) lubricated
check the tention on the w/belt.after that check the drive motor belt if you find lots of black powder your belt is worn out. it dose not have the grip to move the front roller
Dear Sir:
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
Please apply teflon by using the pressurised can provided
with these instructions.
instructions on the teflon bottle carefully.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
the lubricant.
ok
