Integrated Peripherals Menu
1) USB Controller -> Enabled
2) USB Device Legacy Support -> Keyboard + Mouse
3) Use the Down Arrow, and highlight ->
On-Chip IDE Configuration. Press the Enter key.
On-Chip ATA(s) Operate Mode - > Native
ATA Configuration -> P-ATA + S-ATA
S-ATA Keep Enabled -> Yes
P-ATA Keep Enabled -> Yes
P-ATA Channel Selection -> Both
CombinedModeOption -> P-ATA 1st Channel
S-ATA Ports Definition -> P0-3rd
Configure S-ATA as RAID -> NO
4) C.S.A Gigabit Ethernet -> Auto
5) Onboard 1394 Device -> Enabled
6) Onboard Promise IDE -> Disabled
7) AC97 Audio -> Enabled
8) Set Super I/O -> Leave Alone
However let's not cut hairs here.
MAIN thing you need to do F-I-R-S-T, is to write down the settings as they are, BEFORE making changes.
In case a mistake is made, you can go back into BIOS Setup - Integrated Peripherals, and change the settings back to the way they were originally.
This way you can at least use the IDE harddrive, and IDE optical drive, with no SATA optical drive.
Then steam under your collar, find someone who knows more, than Ol' Joe.
(Better to have you ********** at me, than leave you with a non-working computer)
Don't forget to Save Changes, or it will be like you have done nothing at all.
(Need the User Manual for that mobo? Post back in a Comment)
Regards,
joecoolvette
SOURCE: Fitting New SATA Harddrive
Did you check to make sure the sata interface in the bios is on. Not the RAID, just the sata. In the bios settings you'll find it under "Intergrated Peripherals/IDE Device Configuration". Make sure you enable both SATA1/SATA2 and SATA3/SATA4 if your not sure what plug you have your drive plugged into. Good luck.
SOURCE: MSI P4MAM2-V BIOS
Check your Ide data cable it seems 40 pin conductor cable . Replace them with 80 pin conductor cable.your problen\m has gone.
SOURCE: problem with IDE & SATA Hard Disk
Have u tried changing ur jumper setting..which u can find near the power cable to the hard disk...and also U have to enable SATA hard disk in BIOS..
SOURCE: MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
SOURCE: I have a MSI V
this this site http://www.msi.com/product/mb/PM8M-V.html#?div=BIOS and upgrade your BIOS it may help.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
