SOURCE: Panasonic TV TH42px75u plasma just went black and
The 12 blinking lights indicate that the sound sos h board is faulty. But you should check first the power supply. Unplug the tv first then wait for a minute to drain the electric charge in the capacitors before you remove the back cover of your tv. Then try to observed the main power supply board if there is bulged up in the top of the capacitor try to compare the capacitors, the normal capacitor is that the top is flat, or if you see a wet mark or like an oil spill in the bottom of the capacitor try to replace it, because if capacitor is defective it cannot filter the dc and transfer dc voltage output properly to other parts. But when replacing capacitor you should observed the polarity of the capacitor.
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
SOURCE: My 2 year old Plasma
your power supply is defective try to check swollen capacitors and replace it.
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
