Zanussi 24 in. DA6141 Built-in Dishwasher Logo
Anonymous Posted on Jul 30, 2012
Zanussi dishwasher leaking underneath - Zanussi 24 in. DA6141 Built-in Dishwasher
  • 1 more comment
  • Anonymous Jul 30, 2012
    it's not a built in one & took front plastic off but all i got was metal plinth so didn't go any further, probably a seal underneath on a pipe, looked once by tipping machine but how do i get in there safely?
  • Anonymous Aug 03, 2012
    If the only way is from underneath how do I get access, tip the machine, it will leak if i do that won't it, there's always some water in base?
    Leak at front left side only a small amount every time it does a wash, definately not the door seal probably a loose connection underneath?
My zanussi dishwasher zdt12011fa will not switch off and the pump continues to run, obviously trying to remove non existant water! any ideas??
Most dishwashers (especially built in dw) in the bottom has microswitch which is activated if water leaks and runs drain pump to prevent flooding.
Dado
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
2answers
Dishwasher leaking from underneath
Possible that the drain hose is leaking , the drain valve /pump is leaking or the the inlet hose is leaking. You need to observe with a good light under to see the point of leak and infer.
maybe a hose clip is bad and will need to be tightened or the valve needs to be removed , cleaned and reset.
5helpful
2answers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
I have a Zanussi Fitted dishwasher and I notice that the board under my kitchen seems to be getting black,I think it is the dishwasher leaking water from underneath.. Is there any common problems with this...
Yes sounds like some kind of water leak. Take of the front plinth and check underneath the units and DW. I presume you DW is adjacent to the sink so please cheak all pipes including waste asap. Also opening the DW door whilst it is running can splash water, over a period of time this could effect wood material and cause your problem.
1helpful
Zanussi ZDT6252 fills with water when not in use
Sounds like you have a leaking inlet valve. The best option is to replace it with a new one. It does have overfill protection on it but this may not work if its leaking.
Buit in dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
iio
Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
