KLH DVZ-2500 System Logo
Ramasamy Murugan Posted on Apr 03, 2007
DVD Player is not opening the tray
I am using this system for the last 3 years without any issues. After 1 month, I again reconnected with 3 speakers (Centre/FR and FL) alone and tried to use the Home Theatre. The Tuner for FM and AM are working fine. But in DVD mode, when I tried to open the tray, it is not opening at all both through Remote and Manually as well. I removed all the connections and reconnected with the 3 speakers again and tried the same thing. But the same problem exists. Can anyone suggest me what I need to do now?
Anonymous
Level 1:
  • Contributor 81 Answers
  • Posted on Apr 06, 2007
Anonymous
Contributor
Level 1:
Answers
81
Questions
0
Helped
23065
Points
85
There is a belt most likely under the tray that has stretched. replace it with the same size and it should be ok.
1helpful
I have a Samsung HTC 550 home theatre system. It's set to region one and I've tried everything to make it region free to no avail. I want to watch a region 2 DVD. Can you help??
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote. (if your player is already set to region 2)
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Turn off power from remote.
11. Turn power back on with remote.
Player is now Region Free.
or
Turn on with remote control without disc.
When message "No disk" appears, press on the remote,
ENTER,
8,4,2,6,9
ENTER,
If hack work after the second ENTER player will power off automatic.
When power on again this was region free, I can confirm now read region 1, 2 and 4.
tip
If the disc tray doesnt open then follow these tips
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
Hi, I own a HTSS3455 Home Theatre system since 3 years and it worked without any complaints since then but since last month I am facing sub woofer issues ..when I increase the woofer base volume above 5...
Hi, kumar,
I am also using the same model but i got problem in DVD player but my speakers are working fine. I am from Pakistan and here i didn't find the spare part of MPEG main board card. If you wanna buy my Speakers or if you wanna sell ur DVD player contact me on [email protected].
3answers
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
9helpful
2answers
I need to reset the region code on a samsung home cinema system HT-X200
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Thanks
Rylee
11answers
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
3helpful
2answers
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
4helpful
Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
[email protected]
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
