I need the code to connect a Sony DVD player to this TV
SOURCE: Comcast 3 in 1 Universal Remote code for Samsung DVD-V5500
I had the same problem trying to use those three codes with a Samsung DVD-R155 recorder and then downloaded the pdf files for all of Comcast's remotes and came up with two codes (1) 20490 and (2) 21470. The second code worked for me. Hope that this will work for someone else.
SOURCE: SAMSUNG BN59-00599A REMOTE
http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Pages 18-25 should be what you need.
SOURCE: Code for lite on dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
SOURCE: Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
