SOURCE: samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
SOURCE: samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
SOURCE: Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
