Epic 425 Mx Treadmill EPTL88105 ! Logo
Posted on Jul 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removing cover Epic 425 Mx motor hood
Motor Cover Hidden Screws
ernesto cuadra
Level 3:
Top Expert:
  • Epic Master 12,223 Answers
  • Posted on Jul 30, 2012
ernesto cuadra
Epic Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078314
Points
34431
You must have a Lamp for to help the screws. Unless the machine had not screws, must be adjusted to a pressure. You must use the screwdriver for to help to open the hood.
see the video:
1 Related Answer
Anonymous
  • Posted on Jan 03, 2011
SOURCE: I am having trouble removing
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Why does my treadmill not adjust speed? when i press any number it starts running but at a really quick pace. Also, if i put the speed as .5 it will stop.
RUN the software calibration go under the HOOD motor see the instruction, and fix it. see the speed sensor7f016ade-041e-4f50-8a39-9f81109c1be9.gif
God bless you
My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
Motor runs but nothing turns on
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_11_53_47_am.gif11_13_2011_11_54_16_am.gif
1helpful
Epic is sending me a replacement motor for my 425MX. Is it easy to change out the old one? Any secrets I need to know before starting?
You will need to loosen the rear roller off 8-10 turns on both sides to reinstall the motor drive belt...
4helpful
3answers
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
How to remove the motor hood
There are 4 screws across the front. The two additional hidden screws are underneath. Lift the walkboard frame up and they will be through the frame where the end of the hood cover is. One on each side.
3helpful
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
2helpful
IPEC TREADMILL
What I have done, is remove the case to access the incline assembly. tyically a black tube looking thing with a small motor attached to its side. at the end of this motor, you may see the shaft to the motor, with a slot cut in it,.like a flat head screw driver. use a cordless drill with a standard bit attached to rotate the motor manually.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
