I recently bought cambridge audio azur amp,cd etc and hooked it up to my phillips lcd tv via sky & dvd recorder,and now seem to be getting a sound delay from my tv ..... please help.... i've connected tv,sky,dvd with scart leads and also phono leads from sky to amp,also dvd to amp , the delay occurs when i have a dvd on & also when i have sky on. does anyone think it could be a problem with the scart leads as these are only standard scarts and not super special ones,any ideas before i spend £££££££ on new scarts !!!!!!
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
