Clean the Wii with a laser lens cleaning kit like this one:
http://www.amazon.com/Wii-Lens-Cleaning-Kit-Nintendo/dp/B001GZT1UI
SOURCE: wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
SOURCE: Wii wont accept discs
The Wii only does this if you already have a game inside. If there is no game inside request a repai with nintendo.
Make sure you have one year worrinty still. If not become a member of club nintendo. Register it and the worrinty will be extended by 90 days. Then repairs are free! Try it!!
SOURCE: wii unable to accept/eject disc making buzzing sound
SOURCE: my wii is not accepting any disc. I push the disc
I have just finished fixing a wii system that did the exact same thing. It had 2 pennies jammed into it. After i removed them it was perfect. I am a game sytem technician and a special type of screwdriver is required to open the unit. It can be purchased on ebay.Good Luck
