Is there somewhere I can get step-by-step directions for replacing a control board (part# 8201528) in my Kenmore Elite Refrigerator (model# 106.54606300). A repair person diagnosed the control board as my problem (not defrosting), and I can save a lot of money if I can order and install the part myself. I was able to unscrew the screws to gain access to the compartment, but am unsure about the next step -- there are plenty of wires running in and out...
Thanks!
SOURCE: Red light blinking inside freezer
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
SOURCE: Fridge compartment is freezing
It is the part # 2315515. It is a motororized contraption that opens and closes the baffle to let the freezer air into the refrigerator. It is one part. Mine shut closed. I removed the whole thing in hopes I can do without it. It will be a trickey proposition getting the freezer temp adjusted just right enough to keep the fridge just right enough. The repair man said they are seeing alot of these right about now. They don't make em like they used to.
SOURCE: Kenmore refrigerator 106-54606300 that has
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: How do I replace the defrost control board on a
The board is usually in the fridge side up by the controls and usually is hidden. If you take your model number and go to apdepot.com or partselect.com you can get an illustrated breakdown of the machine and where each part is
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
