Safety clip
Here is the safety key for the Weslo Cadence C22. There are a few different model numbers for the cadence c22 so make sure yours is listed but it looks like this key works for multiple versions of the c22
SOURCE: i have weslo cadence 860 ,the key is not working
Is it the magnetic key or the red one you slide into the slot.
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
I did not see anything but the comment. Thanks.
