I hooked it up to an RCA digital amplified antenna, but only receive static on all channels. when I check the signal meter it is strong, but no picture. I already tried switching the input configuration from Cable to Antenna, there are several broadcasting stations within range, I have re-positioned the antenna everywhere and it makes no difference. I dont get any picture on any channel.
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Toshiba 37HLX95 no audio only on over-the-air
Swap input 1 and 2 and see if you get same result - could be a bad tuner in the set (#2).
SOURCE: Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
