No directions for assembly of the stand that goes with the keyboard CDP-220R
SOURCE: displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
SOURCE: Need to get instructions how to use the metronome
Check the manuals for the Eurogrand EG540/EG1040 (which are apparently similar but discontinued) at this site:http://behringer-en.custhelp.com/cgi-bin/behringer_en.cfg/php/enduser/std_alp.php?sm=2
SOURCE: casio cdp 100 problem:
Try this link for the manual:http://support.casio.com/pdf/008/CDP100_e.pdf
SOURCE: Proline Piano Keyboard Stand Assembly Hi, I just
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Testimonial: "Thanks so much that really really helped and was a life saver because I am really bad with figuring out directions and assembling things. Thank you!"
