Vodafone 845 Cell Phone Logo
Posted on Jul 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone no sim card problem
My android cell says "no SIM card" even though my sim is in it ....i removed the battery and card but nothing....what can i do to fix it?
Computer Repairing
Level 3:
  • Vodafone Master 14,641 Answers
  • Posted on Jul 29, 2012
Computer Repairing
Vodafone Master
Level 3:
Answers
14641
Questions
0
Helped
718758
Points
53082
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
1 Related Answer
Anonymous
  • 160 Answers
  • Posted on Feb 08, 2011
SOURCE: my motorola phone does not
Where did you get the handset from. If this is from Vodafone then you will need to spek to them.If the handset is not you might need a handset unlocking code.
tip
How to Sync SIM Card Contacts with Gmail of your Android phone
<p>You can use your SIM card contacts to your phone Android on your Gmail account, importing contacts in the phone memory. No additional software required. You can use the contacts on the phone and then sync them from the operating system Android. Depending on the operator, manufacturer and version of its Android operating system, the settings a little different, but most android phones use the same steps. <br /> <p><br /> <p>1. Open the screen of your Android phone and tap Contacts. <br /> <p><br /> <p>2. Press the "MENU" and press Settings. <br /> <p><br /> <p>3. Select "Import from SIM card" and press "OK". <br /> <p><br /> <p>4. Press the "Home" to return to the main screen and press "MENU". <br /> <p><br /> <p>5. Tap Settings and then Accounts. In some Android phones, is this option called "Accounts & Sync." <br /> <p><br /> <p>6. Tap your Gmail account and check the "Sync Contacts" is checked. <br /> <p><br /> <p>7. Press "MENU" and press "Sync Now". <br />
on Aug 18, 2011 • Google Android
tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 • Cell Phones
2answers
Screen all of a sudden is saying "Check SIM" or "Insert SIM" though no trauma has happened to the phone.
This "Insert Sim"(even though already Sim inserted means) or "Sim Error","Invalid Sim",are all problem arises means that Mobile Locked to Some Network,You need to Unlock it to use other GSM Sim Card,You can Unlock the Motorola KARMA QA1 model using the Unlock code at reliable price at this site
http://www.wickedunlock.com/motorola-karma-qa1/rs11wp9/
1helpful
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 • Cell Phones
Whenever I Turn On My Phone It Says That The SIM Card Must Be Inserted, Even Though It's Already In.
The SIM card may not be making proper electrical contact in the cell phone.
Try removing the SIM card and cleaning the SIM card contacts and the SIM card contacts in the cell phone with methylated spirits. Then replace the SIM card in the cell phone.
I am getting the message "check SIM " ---where is
It's at the back of the phone. After removing your battery case, remove the battery and it's there!
Hope this helps
We insert sim card in cellphone, even though the cell phone dispaly "please insert sim card"
It seems that your cell phone is having trouble reading the SIM card. You have two options. First you can attempt to clean the SIM contacts on your device. To do this simply apply a small amount of alcohol to a Q-tip and gently rub over the gold contacts where the sim card normally goes, this will help to remove any dirt build up and provide a better connection. Second, contact your service provider and request a new SIM card. Sometimes SIM cards can go bad similar to a memory card failing. A new SIM card maybe all you need.
1helpful
Phone sporadiacally displays "insert sim card" even though it has a sim card inside (never been taken out). Switching off the phone and switching it on again was what i did. However recently my...
it could be that the contacts between the phone and the sim card are dirty and therefore you will get the error code. take the battery out and remove the sim card take a q-tip with some rubbing alchohol and clean the contact on sim card and the phone itself make sure not to use alot of alchohol. let them air dry then re-insert the sim and battery this should do the trick. the error warning should go away and the phone will be abale to receive the contact info from gthe sim card.. please rate this
Sep 20, 2008 • Cell Phones
Top Vodafone Cell Phones Experts
Kolbrun...
john h
 Mikey
Mikey
Are you a Vodafone Cell Phone Expert? Answer questions, earn points and help others
