What retailer sells swingline 101 staples it is a heavy duty hand held stapler
Hi, you can purchase them on amazon, here: Amazon com swingline 101 staples I hope this was helpful. Have a nice day
FOR THE 101 TACKER:
TRUE VALUE:
PART #243706 FOR ¼"
PART #659816 FOR 5/16"
OR:
WWW.EBAY.COM AND WWW.AMAZON.COM Under the Surebonder Part Number as follows:
¼" is 44114
5/16" is 44116
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
SOURCE: I need 1/4"staples for my Swingline Heavy Duty
http://www.staples.com/Swingline-Heavy-Duty-Staples-1-4/product_504225
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
SOURCE: swingline heavy duty stapler wont
I'm having the same problem,...... Ugh,.. The stupid lil bendy thing that u put in the groove for the staples that u attach to the spring took me forever to put in place.. And I think it make have gotten out of place when I finally kept it in place long enough to close it,.
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
FOR THE 101 TACKER:
TRUE VALUE:
PART #243706 FOR ¼”
PART #659816 FOR 5/16”
OR:
¼” is 44114
5/16” is 44116
I bought some a while back on Amazon and by the time I got to use them found they were for a regular desk type stapler, not the tacker. Be careful what you buy.
Do not order staples without having the proper part numbers. FOR THE 101 TACKER:
TRUE VALUE:
PART #243706 FOR ¼”
OR:
¼” is 44114
5/16” is 44116
44114 and 44116 are avaiable www.surebonder.com they are the surebonder #2 staple
