NEED MANUAL SO THAT I CAN OIL IN THE PROPER PLACES. THANKS IN ADVANCE FOR ANY HELP YOU MAY GIVE ME.
SOURCE: Machine don't work.
hi there,
huming of motor means this will not run it could not start due to no tourque to induce voltage to start,since this is a brand new machine recently purchased it has warranty, go to your nearest service center and claim the warranty of this sewing machine.
regards don't forget to rate me thannk's
SOURCE: I need the owner's manual
Hi, Justmanuals.com has the manual that you need. They do charge $11.77 for each manual. If you're interested, just follow the link below. Hope this helps! Hal
http://www.justmanuals.com/sewing-machines-c-353.html
SOURCE: need to replace Brother CS6000i power cord
Hi! Guy at http://www.sewingmachineparts.net/ always seems to have what I need. Here are a few other sites:
http://jhittlesewing.com/sewing/catalog.php
http://www.mastersewusa.com/accessories.html
http://sewingpartsonline.com/
And finally, Brother's website: http://www.brother-usa.com/homesewing/
Good luck and let me know if this works.
Robbie
SOURCE: My Brother CS6000i manual does not mention oiling. Should it be?
i was able to find it at www.ifixmachines.com
SOURCE: Hi my sewing machine is
The most common fault on sewing machines is bad threading or poor needle. Start with a fresh needle even if you have just changed it. Make sure its up as far as it will go. The Long groove should be facing you and the flat to the back away from you. A thicker needle is less likly to cause skipping. If the fabric flapps as it sews it may skip (flagging). If the fabric is stretchy, that can make it skip... solve by sewing a tape in for support. If that fails undo the needle clamp screw and pull the needle down slightly by say about 0.5mm. Tighten the clamp screw firmly. Turn the machine by hand to make sure the needle is not striking the parts within the machine. Test sew again. If that dont work all you can do is take it to an engineer. Dont let him sell you another. Its what they do. If they try, go elsewhere.
