It is a 42 inch lcd flat screen tv that has a black line down the right side that shows up when in full screen mode going from about 2 inches from the top to about 2 inches from the bottom of the screen. Over the past 6 months it seems to have gotten darker and larger. The tv is only 2 years old.
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables
along the side and top. On your unit, some of these many, tiny
connections are making contact intermittantly thus losing the elements
in that area. These contacts are held in place with just pressure and
if that is disturbed, you lose that line of elements. Try squeezing the
cabinet of the TV on the outside at the top in the area of the loss and
see if that makes a difference. May have to go inside and see if the
contact assembly is disturbed or warped or something.
Hope ya fix it!
SOURCE: shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
