Sony Ericsson Xperia U Black Rubber Gel Case Cover Logo
Posted on Dec 29, 2017
My xperia U's screen is blank abd when I turn it on like I normally do it just lights up a navy colour. The light at the bottom still works and the everything.
I've had my phone 2 days, and its been working great. I suddenly come back to it, turn the power button on to light the screen up, and it turn on. The bottom light lights up like normal and so does the charging button. What should I do? Also when I clicked the button it lit up in a black/navy colour.
5 Related Answers
A
Anonymous
  • Posted on Jul 07, 2007
SOURCE: s710a problems
I am having the same problem - it won't hold a charge. Red light shows it is charging, but nothing. It may be the battery. I just called S.E. and they said it may be the battery. I ended up getting a new phone since batteries cost almost as much as a new phone.
A
Anonymous
  • Posted on Apr 20, 2008
SOURCE: Won't turn on S710a
Your problem is this phone is equiped with a 23-44 pressure sensor, let it set for 4 or 5 days to reset. thats what i did, oh take out the batt.
Anonymous
  • Posted on Apr 22, 2008
SOURCE: My sony ericsson s710a mobile
how do i unlock it from a phone lock code....
Anonymous
  • 113 Answers
  • Posted on Nov 01, 2008
SOURCE: Sony p1i display screen problem or software problem??
sorry to say the display ic might have knocked off. if soft ware problem u wont might be able to make and receive calls either
Anonymous
  • Posted on Jun 18, 2009
SOURCE: phone doesnt turn on, lights on but screen stays black
its BROD " Blue Ring of Death" try to use A2 uploader then flash FS, MAIN and CDA... if you cant then send your phone to me... i always experience BROD...
I got a problem with my Xperia play it's screen got struck nd became full of colourful dots buttons have not worked I even factory reset it but no use.What to do..??
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 02, 2012 • Cell Phones
2answers
Laptop screen has gone blank
I assume that your laptop's display has been damaged. Are you sure that other things are working normally? If other components are working, then problem will be with the display unit. Try to repair or replace with new one.
My HP pavillion g series,it turns on but the screen stays blank and dark
My computer doesn't flicker any colour before it goes blank etc. When i turn it on, the screen is blank/black and It says its on.. by the light being lit up, but nothing happens. :/ I don't understand, whats the problem?
2answers
How do i connect my nokia 6230 to gprs
Hiiiiiiiiiii....................
Nokia 6230 GPRS and WAP Internet Settings
You'll need to complete all steps for this to work.
The phone has a 4 way directional 'Navi' key and 2 soft keys either side of this.
To insert the required symbol (e.g. : / . @) into your settings, simply press the * key, highlight the appropriate symbol and press the Use key to select.
1. Press Menu button (Navi key).
2. Scroll to 'Settings' and press 'Select' (Navi key).
3. Highlight 'Configuration' and press 'Select' (Navi key).
4. Highlight 'Personal Configuration Settings' and press 'Select' (Navi key).
5. Press 'Add' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Web' and press 'Select' (Navi key).
7. Highlight 'Account name' and press 'Select' (Navi key).
8. Enter 'giffgaff GPRS WAP' and then press 'OK' (Navi key).
9. Highlight 'Homepage' and press 'Select' (Navi key).
10. Enter 'http://giffgaff.com/mobile' then press 'OK' (Navi key).
11. Ignore 'User name': Leave blank.
12. Ignore 'Password': Leave blank.
13. Highlight 'Use preferred access point' press 'Select' (Navi key).
14. Highlight 'No' and press 'Select' (Navi key).
15. If asked to 'Define access point settings' then press 'OK' (Navi key).
16. Highlight 'Access point settings' and press 'Select' (Navi key).
17. Highlight 'Proxy' and press 'Select' (Navi key).
18. Highlight 'Enable' and press 'Select' (Navi key).
19. Highlight 'Proxy address' and press 'Select' (Navi key).
20. Enter '193.113.200.195' and press OK' (Navi key).
21. Highlight 'Proxy port' and press 'Select' (Navi key).
22. Enter '8080' and press 'OK' (Navi key).
23. Highlight 'Data bearer' and press 'Select' (Navi key).
24. Highlight 'GPRS' and press 'Select' (Navi key).
25. Highlight 'Bearer settings' and press 'Select' (Navi key).
26. Highlight 'GPRS access point' and press 'Select' (Navi key).
27. Enter 'giffgaff.com' and press 'OK' (Navi key).
28. Highlight 'Authentication type' and press 'Select' (Navi key).
29. Highlight 'Normal' and press 'Select' (Navi key).
30. Highlight 'User name' and press 'Select' (Navi key).
31. Enter 'giffgaff' and press 'OK' (Navi key).
32. Highlight 'Password' and press 'Select' (Navi key).
33. Enter 'password' and press 'OK' (Navi key)
34. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
35. Press 'Back' (right soft key) 3 times.
36. Highlight 'giffgaff GPRS WAP' and press 'Options' (left soft key).
37. Highlight 'Activate' and press 'Select' (Navi key).
38. Press 'Back' (right soft key) 4 times to return back to the standby screen.
Switch your handset off and then back on to complete your settings.
The GPRS WAP settings are now complete.
Nokia 6230 MMS Settings
4. Highlight 'Personal configuration settings' and press 'Select' (Navi key).
5. Press 'Add ' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Multimedia msg.' and press 'Select' (Navi key).
8. Enter 'giffgaff MMS' and then press 'OK' (Navi key).
9. Highlight 'Server Address' and press 'Select' (Navi key).
10. Enter 'http://mmsc.mediamessaging.co.uk:8002' and then press 'OK' (Navi key).
11. Highlight 'Use preferred access point' and press 'Select' (Navi key).
12. Highlight 'No' and press 'Select' (Navi key).
13. If asked to 'Define access point settings' then press 'OK' (Navi key).
14. Highlight 'Access point settings' and press 'Select' (Navi key).
15. Highlight 'Proxy' and press 'Select' (Navi key).
16. Highlight 'Enable' and press 'Select' (Navi key).
17. Highlight 'Proxy address' and press 'Select' (Navi key).
18. Enter '193.113.200.195' and press OK' (Navi key).
19. Highlight 'Proxy port' and press 'Select' (Navi key).
20. Enter '8080' and press 'OK' (Navi key).
21. Highlight 'Bearer settings' and press 'Select' (Navi key).
22. Highlight 'GPRS access point' and press 'Select' (Navi key).
23. Enter 'giffgaff.com' and press 'OK' (Navi key).
24. Highlight 'Authentication type' and press 'Select' (Navi key).
25. Highlight 'Normal' and press 'Select' (Navi key).
26. Highlight 'User name' and press 'Select' (Navi key).
27. Enter 'giffgaff' and press 'OK' (Navi key).
28. Highlight 'Password' and press 'Select' (Navi key).
29. Enter 'password' and press 'OK' (Navi key).
30. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
31. Press 'Back' (right soft key) 3 times.
32. Highlight 'giffgaff MMS' and press 'Options' (left soft key).
33. Highlight 'Activate' and press 'Select' (Navi key).
34 Press 'Back' (right soft key) 4 times to return to the standby screen.
35. Press Menu button (Navi key).
36. Scroll to 'Messages' and press 'Select' (Navi key).
37. Highlight 'Message Settings' and press 'Select' (Navi key).
38. Highlight 'Multimedia Msgs.' and press 'Select' (Navi key).
39. Highlight 'Configuration Settings' and press 'Select' (Navi key).
40. Highlight 'Configuration' and press 'Select' (Navi key).
41. Highlight 'Personal Config' and press 'Select' (Navi key).
42. Highlight 'Account' and press 'Select' (Navi key).
43. Highlight 'giffgaff MMS' and press 'Select' (Navi key).
44. Press 'Back' (right soft key) 5 times to return to the standby screen.
The MMS settings are now complete.
Enjoy............
I have a Dell 600m insiron laptop. When I turn it on it starts up like normal. There's 4 lights on the bottom of the monitor the first light on the lift light up and stays on. The second light blinks...
Try to turn it on with the battery removed, as a failed battery could be the root cause of this issue. If this turned out to be the case, then consider replacing the battery with a new one.
Blank screen
pull the battery from it for a little while , if that don't do it its probably a display chip inside and it can't be replaced , they have been having problems with the screens on these phones , does the phone still work for recieving and sending calls? its not likely but not impossible the screen went
Top Sony Ericsson Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
August Brown
August Brown
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
