I have a problem:
I just bought a Xacti 1000 and a 16GoB SD(HC) card (Class 6, from Apacer).
When I first powered my cam with the card in it, and selector on CAM, I read the message "Format / FULL FORMAT", and the cam said ("problem with the SD card", with a woman's voice...!).
I tried a few things:
- tried to re format the card with the cam: the process stopped 2h30 latter with the batt low level... (2 times),
- put the card in a computer: but it was not even detected;
- tried another PC wich could see the card and formated it in a 1 partition FAT32 format (as specified in the manual),
Nothing worked! then I tried another card (1Gb Scandisk SD card):
-same screen on Xacti: "FORMAT / FULL FORMAT"
-formating with Xacti didn t succed either....
Given that I saw this cam working (the seller demontrated the cam right when I bought it!), I assume it should work and I am doing something wrong, or I should do something that I DON'T know!!!
HELP!
Duration of FORMAT/FULL FORMAT for VPC-HD1000.My email:
[email protected] THANKS. I use Sandisk ULTRA II 8 GB.
What was the speed of the second card? Scandisk are good cards. I think that the only important difference between cards is the speed.
You could try formatting with the camera in connected to the recharging shoe thing.
This card is not compatible with your camera try another brand!
This should fix ya! ( ( all sd cards may look alike but they are not!)
I have the same problem with a 1GB card because I shot the "Full Format". and now I must buy another one. For now on you must press the "Format" key not the "Full format". Is a problem with this "full format" I think.
