SOURCE: leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
SOURCE: Light dimmer issue
the light on the switch does not men it is wired correctly, it only means that you have supplied power at that point. Without knowing more its hard to say, but I'll assume this is a single switch operating a single unit. That being the case, and depending on your fixture, occassionally wires must be grouped together on the switch side. Also quite often these switches are simply defective, and must be returned. If you think you have it correct then its probably a bad switch.
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
SOURCE: Leviton Dimmer Switch wiring and
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
SOURCE: replacing old switch, existing leviton dimmer has
Hook one of the wires that was connected to the black wire to the silver screw, one to the brass screw. Does not matter which. If there is no ground (bare or green) then you can hook one from the green screw on the switch to the box where the other grounds are connected.
